Old 10-29-2018, 06:41 PM   #1
Nedlands
Originally Posted by dav9515 View Post
i had the same issue, i was getting quotes up to $1,800 for Water Pump, Thermostat, and Front Motor mount, labor only!!! it was insane!
Kept looking and found a reputable shop to do the work for $600. Still not cheap but seeing as though most indy quality shops are charging a minimum of $150 hr these days it's hard to find reasonable prices for work. Need to locate a place that charges actual labor and not book rates then use them regularly so you build a relationship.
Even $600 for labor is high! That job should take about 2 hours all in, or at least that's what it took me
Nedlands is offline   Reply With Quote
