Old 09-18-2006, 08:22 PM   #1
MNBoxster
Originally Posted by motoadve
The manual says it would be to extense to explain all the insructions on how to owrk the onboard computer.
Is there a place where I can get instructions?
Can I change radio stations, advance songs in the CD player ect
I have 05 base Boxster with Trip.
Hi,
The OBC hack is fairly simple, but a little involved. It can be done in about 45min.-1Hr. Here is a pretty good instruction: http://www.whiteson.org/boxster/mods/obc/obc.stalk.pdf
Bear in mind that this is for a 986, but the procedure should remain pretty much the same. You will need to have a dealer turn-on the OBC function. Many will do this to display the ambient temp, but on the '03+ cars, you need to configure a little wiring to get it to work and add a switch or 4th stalk to make it fully functional. Hope this helps...
Happy Motoring!... Jim'99
