Old 09-18-2006, 04:07 PM   #4
ohioboxster
ohioboxster's Avatar
Originally Posted by Frank
Hi,
I recently had my MAF go bad.The car ran real bad on startup in the morning. It accelerated horribly and was just slow.I got the codes read at autozone and it said oxygen sensors,well it was the MAF and not the oxygen sensors to make a long story short. To figure out if that is your problem,just disconnect the wire for the MAF and it will put the computer into default mode,your car will run great if that's the problem.By the way,don't buy the bosch universal oxygen sensors if you ever need to replace any of them,they don't work .
Frank
Frank,
It worked! I pulled the harness off the maf sensor and the car started right up cold with no stumble. I kept it out of boost and drove it home with no issues. That was a great idea unplugging the maf! It kept the values set and allowed me to eliminate the maf from the equation, Thanks!
2002 TT
ohioboxster is offline   Reply With Quote
