Old 10-24-2018, 06:29 AM   #1
Burg Boxster
Do NOT let all the fluid drain out when preventing such is so easy. (Not to mention clutch is still fed by master cylinder...)
Either cap off line at each corner w/ a golf tee or wire nut. Or if replacing brake lines in spring then just crimp each with a small a clamp or pair of locking pliers. Some will still drip using either method so wrap w/ a zip-lock bag if worried about any spillage.
Good luck
"Cool Prius!"
- Nobody
