Old 10-19-2018, 10:19 PM   #15
AZ986S
AZ986S's Avatar
when we are dealing with drops over fractions of a second, the time for the pressure sender to detect and open a valve is significant. if the only downside to having the valve open all the time is potential depletion of the pressurised oil supply, then using an accelerometer to open the valve in an anticipatory basis is a good compromise. OR, i presume you are using the 40 psi switch; what about the 55 psi switch that might catch dips a little sooner?
I thought about using the 55 psi pressure switch. I think the issue is that the oil pressure would be mostly bellow that, so in effect it would be always open. Today I installed a manual pressure switch "bypass" toggle switch so that I can keep the valve always open when needed. I will test that next weekend at AMP again, this time with PCA. I will set the Accusump Air pressure at 15 psi. This should give me 1.5 qts in the Accusump @ 60 psi, then 1 qt @ 30 psi, so about 0.5 qts to play with in real terms. If you start with 30 psi, the starting volume is 1 qt @ 60 psi, and @ 30 psi, it becomes 0 (empty). In theory, the response time is quicker at higher air side pressures, but you also start with less oil.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
