Old 10-13-2018, 02:14 PM   #15
marsheng
Most likely, your wiring has developed an intermittent short over the years.
Totally agree. By upping the fuse, you are allowing a higher current to flow through the wires that have been designed for and potentially you are making for the possibility of starting a fire or making smoke signals. I know its hard to find a short, but it is what is needed. I have found the wiring not the best in the Boxster with no real covering in the wiring looms. Any vibration/rubbing against the chassis goes through the current carrying wires and not the covering sheath.
Cheers Wallace
marsheng is offline   Reply With Quote
