Old 10-08-2018, 02:06 PM   #10
Geof3
Originally Posted by rfuerst911sc View Post
I am curious so asking this question , if you disconnect the negative cable will you still be able to electronically open the frunk ? I'm thinking you need to open the trunk to activate/flip the disconnect switch .
Depends. Mine has a small wire that connects to chassis ground to allow enough power to run accsessories, but won’t start the car. Or, move the frunk cable release to where it is accessible via the tow bolt access.
