Old 10-08-2018, 02:43 AM   #11
rfuerst911sc
Originally Posted by Geof3 View Post
For now, put a negative battery shut off/disconnect on the car. It is easy and inexpensive. At least until you figure out a better solution.
I am curious so asking this question , if you disconnect the negative cable will you still be able to electronically open the frunk ? I'm thinking you need to open the trunk to activate/flip the disconnect switch .
rfuerst911sc is online now   Reply With Quote
