Old 10-07-2018, 04:52 PM   #13
aussieboxy
Clutch Bleeding
So I have replaced the slave cylinder & bled it using the method found on this forum of utilising the rear left brake caliper & running a small clear hose to the clutch slave cylinder & pumping through the brake fluid. Did this 5 times with the clutch depressed & not drepressed but the clutch is still not working.
Apart from contuing to bleed I'm lost for idea's.
Any suggestions would be appreiate
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
