Old 10-03-2018, 05:40 PM   #1
daviddelpauley
daviddelpauley's Avatar
Exclamation Help Please-2002 986 Overheating
Hello everyone!
I’ve been having overheating issues with my 986 2.7l five speed base ever since I started repairing it from hitting a huge pothole.
Initially, I busted my passenger side radiator and ordered an aftermarket one from ********************************. While swapping my busted radiator out for a new one, my mechanic cracked the metal pipe belonging to my passenger side condenser, but was told I could drive it like that in the meantime but I just would not have A/C since all my freeon released once the damage was done to the condenser. Will this actually cause my overheating issue?
I have also considered the fact that it might need to be bled out for airpockets since a brand new radiator was installed, but want more opinions and ideas.
Once the temperature hits around the 250° mark you can pop the trunk and feel heat, as well as see droplets of coolant right around the coolant cap where it appears to be abnormally pressurized. It appears I’m losing coolant as well and need to top it off every time, however I cannot find a leak anywhere. I haven’t lifted up the trunk carpeting yet to check the reservoir for cracks or leaks, but I am willing to bet that is not where my issue lies regardless, but will check tomorrow anyway.
Thanks in advance for any help or ideas.
daviddelpauley is offline   Reply With Quote
