Old 10-03-2018, 11:03 AM   #1
seningen
seningen's Avatar
Where are you making the connections when jump starting? The neg post of the battery or to ground on the car? You could be making a circuit to ground that is open by the DME when bypassing the battery.
I ask because a lot of electronics make connection to ground to complete the circuit. Maybe a ground wire from battery to jump point?
I connect to the lead which would be connected to the battery ground when
jumping. I.e. I pull the lead off the battery and jump from there (although I have also clamped onto the body ground post with the same results).
I replaced the ground lead with no difference in behavior.
The positive jumper cable connects to the positive battery post.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
