Old 09-29-2018, 05:37 PM   #20
WindS
Help with diagnosis, please....
I've got the same issue where the blower fan doesn't work. I tested the fuses and swapped the relays. No difference.
I got to the fan and tested the voltage on the 2 leads to the fan = 12V. So the fan has to be toast right? So I install a new cheap fan and it doesn't work either. I confirm 12V.
I did a few more measurements. I get 12V at the 2 terminals and a 1000-ohm resistance. I've got no idea about the resistor value. 1K-ohm seems like it's likely in there to prevent the fan from going.
Logic says the new fan is bad too. I don't have a 12V power supply to test the old one. Can there there be something else wrong. Is this too much resistance. The fan should be getting 0.012Amps. Not enough?
Thanks.
WindS is offline   Reply With Quote
