Old 09-29-2018, 03:14 PM   #4
flouese
flouese's Avatar
Did you bench bleed the master cylinder BEFORE installation? If not and you weren't careful you have pushed air into the ABS pump and system. There is a procedure to do solve this I just don't have ATM. Off hand it will involve activating the ABS using a Durametric and bleeding.
No I did not bench bleed the Master cylinder. I don't have a Durametric. Is there a "shade tree" remedy for this???
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
