Old 09-26-2018, 07:48 AM   #1
speedyspaghetti
Originally Posted by Era Vulgaris View Post
Are you saying you put a continuous line of chalk on both the tire and the wheel, and after driving some distance the chalk line "split" into two lines on the same tire/wheel?
Or are you saying you marked lines on your front and rear tires, and after driving they are no longer aligned in the same direction? This instance, along with center caps, are impossible to keep aligned from front to rear because your front and rear tires are different sizes. And they won't stay aligned passenger side to driver side, because when you make a turn the outside wheels turn more than the inside wheels.
But if it's the first case, where the single line on one tire/wheel splits into two, that's freakin weird man.
You know, I think I need to re-do my test. I had some doubts while I was falling asleep last night and this morning I checked and my center caps are a bit loose on that side compared to the other. I'll re-check tonight and report back.
speedyspaghetti is offline   Reply With Quote
