Old 09-23-2018, 11:45 AM   #8
speedyspaghetti
i get vibration at speed. what research i've done indicates that the issue is with worn bushings in the front lower control arms. you can get your mechanic to go at it with a crowbar to see if there is any play, but typically the wear is only really apparent upon removal of the lca and visual inspection.
I've replaced all four control arms with Meyle OEM parts - anything else that could be contributing to this?
speedyspaghetti is offline   Reply With Quote
