Thread: frunk issue
Old 09-18-2018, 07:56 AM   #1
Blackcloud
Originally Posted by Anker View Post
Me too!
After Autocrossing hard in hot weather exactly the same symptoms. I ended up replacing the latch (got the "new" one from Woody). Not a hard job at all and everything worked as it should at the next AX. Then this spring when I cleaned my radiators and put screens in the intakes I discovered that the right cooling fan wasn't working and replaced it. I believe the heat from the radiator with the bad fan contributed to the problem.
Hey Anker. Nice meeting you at the zone. I was walking the course with you.
Blackcloud is offline   Reply With Quote
