Old 09-16-2018, 11:01 PM   #1
Geof3
looks like it actually has to be shifted back 1/16" or so, and in the act of moving rearward it will also move out a bit. there may be enough play in the bolts that mount the clamshell to the bracket to accomplish that?
Are you talking about the rail the mechanism runs on? The lever arms are all pivot pins with no real adjustment. The bolts that connect the arms to the channel rail do have an eccentric bolt, but that seems to adjust the height along with the other various adjustment points. I can’t figure out any other options short of perhaps the cable timing is a tiny bit off, or perhaps one is stretched. I haven’t looked at the motor/cable connection yet, I don’t really want to mess things up just for a relatively minor body line issue...
