Old 09-12-2018, 11:26 AM   #10
Gilles
Originally Posted by alcubot View Post
have you any idea?
Yes like 78F350 says…
First Clean everything well, then run the engine and you should be able to see the source, I guessing the AOS, or the accordion hose that connects the crank vent valve to the AOS.
Other possibility would be a leaking oil sump cover, again clean everything first…
PS: Use a can (or two) of engine degreaser and hose it off with "LOW pressure water" and you will be surprised of the results (tip: if you first hose down the floor, all the gunk from the engine will not stick to the floor and you should be able to hose it down easily afterwards
