Old 09-10-2018, 10:32 AM   #3
speedyspaghetti
If you use this, you still need something to pull the hub which can be a slide hammer or some folks have used lug bolts and pressed it out by pushing against the carrier, I have only seen videos of this with other cars though.
I don't know which of the Amazon kits, here is the thread but it doesn't say which kit:
https://986forum.com/forums/boxster-general-discussions/72020-wheel-bearing-replacement.html
Ok, so the OTC grappler would be used for the hub? Or would I still need a slide hammer to get the hub out?
speedyspaghetti is offline   Reply With Quote
