Old 09-10-2018, 09:48 AM   #14
steved0x
steved0x's Avatar
Originally Posted by speedyspaghetti View Post
Are you referring to this tool?
https://www.harborfreight.com/front-wheel-bearing-adapters-63728.html
Did you have to use any other tools in conjunction with it?
If you use this, you still need something to pull the hub which can be a slide hammer or some folks have used lug bolts and pressed it out by pushing against the carrier, I have only seen videos of this with other cars though.
I don't know which of the Amazon kits, here is the thread but it doesn't say which kit:
https://986forum.com/forums/boxster-general-discussions/72020-wheel-bearing-replacement.html
