Thread: PS Line Replace
Old 09-05-2018, 08:27 AM   #5
thstone
And yes, it leaks at the plastic (it's not rubber) hose where it goes into the fitting. Not from the connection point of the fitting. Both ends are leaking this way. Have you seen this before? Odd to me, as this is supposed to be the low-side, return. Should be very low pressure. Right?
I assume that you mean that the line is leaking at the red arrows. If so, it is probably not related directly to pressure - any stress on the line (usually bending but could also be axial) can cause a leak where the connector attaches/seals to the line itself. Either way, now that you know where the leaks are, they are a fairly straightforward repair.
