Thread: PS Line Replace
Old 09-03-2018, 03:38 PM   #2
Gilles
I also have a leak where it goes into the steering rack.
I see that Pelican sells O-rings for the power steering. This isn't just that simple is it,?
Hello Maytag,
Yes, as long as you use the correct size O'rings it should take you a few minutes to replace them, as previously mentioned by Tom, the two hoses are held in position by a single bolt and plate (a surprisingly simple design used across the all VW product line).
Good luck,
Gilles
Gilles is offline   Reply With Quote
