Old 09-03-2018, 01:32 PM   #2
Spirit_RE
Originally Posted by 356Guy View Post
"If I look at the current wiring and the Continental and Becker diagrams I see the problem:
My current wiring does not use the B block (apparently this is unused in HiFi option/Nokia cars)
My current wiring uses the C block pins to send the signals to the amp; the Continental diagram doesn't show that these are used for anything. It only mentions C4 and C6 for SWRC.
The only output to the amp on the Continental is the B block which explains why I have no sound because it is not being used
I therefore need a harness that goes from the Continental B block to the existing harness C1 block.
Ha, my thought process as I was figuring this out was exactly the same. As soon as I stopped simply putting square pegs in square holes and actually thought about it....
Spirit_RE is offline   Reply With Quote
