Old 08-30-2018, 10:11 PM   #1
Geof3
Three things in order- 1: as mentioned, trans fluid Porsche brand. 2: 997 shifter 3: motor mount, if not done prior, for sure it’s toast with that many miles. Bonus, maybe trans mounts (unlikely)
If second gear is grinding, and/or popping out when cold your second gear syncros are on the way out. If you just get occasional pop out of 2nd when cold, with no grinding, the Gbox detent fix can solve that issue for a time.
