Old 08-17-2018, 06:38 AM   #43
jdlmodelt
If there is a voltage regulator resident on the cluster, it could drop out like you are seeing with the flashing when it is going bad or when it is not getting adequate voltage input. It does seem strange that your B1 voltage fluctuates as much as it does. The flashing could also be a voltage regulator dropping out to protect itself from a short somewhere. Troubleshooting can be a major pain! You said this all started after replacing the battery?
