Thread: Top Stuck Down
Old 08-14-2018, 12:53 PM   #3
Cunningr
Cunningr's Avatar
Check to see if your parking brake light is on when you pull handle, if it is not then the parking brake sensor is bad located in the parking brake handle.
Easiest solution but not cheapeadt is the easy top realy, plug and play, micro switch is around $8 but you have to take apart the console, look there is another working aroung where you bend pin 15 I think it is on the top relay then solder a wire the ground it out.
To get top up try working the hand brake up and down to try to jar the switch to close.
If the hand brake light is on then as mentioned the latch micro switch possibly.
