Old 09-14-2006, 07:22 AM   #1
MNBoxster
Originally Posted by ohioboxster
I found my vacuum leak with a can of starting fluid, just mist the vacuum lines and around the throtle body etc. What scan tool are you using?
Hi,
That is the traditional method. One can also use an unlighted Propane Torch, Butane refiller, even a Bic lighter - of course, extreme care (open air, fire extinguisher within reach, etc.).
What OHB failed to mention is that you're looking for a surge, or drop, in the idle a second or so after you spray the substance on the suspected leak. Repeat spraying the suspected area a couple of times to confirm your results. Hope this helps...
Happy Motoring!... Jim'99
