Old 08-07-2018, 06:53 AM   #2
Aanic
These headlights are famous for the insulation baking off of the wiring inside the headlight. I'd pop it out and have a look.
And, basic troubleshooting: swap bulbs, side for side. See if the problem moves, or stays put. It wouldn't be the first time someone bought and installed a new, BAD lamp.
So to make sure I track, you are saying the wiring in the headlight housing itself is possible burnt?
I will try swapping bulbs when I pop out the unit to check the pins.
Aanic is offline   Reply With Quote
