Old 08-07-2018, 06:00 AM   #2
Aanic
You have a Higgs Beam? Some people at CERN want to talk to you.
Seriously, though...
Have you checked the fuse (A1)? Visually inspect the wiring inside the headlight for signs of broken or missing insulation and make sure the headlight main connector pins aren't bent.
Part of that limited edition God Particle Boxster run they did...
Would the fuse affect just one high beam? Will double check the connector pins when I get home and have daylight.
Aanic is offline   Reply With Quote
