Old 08-06-2018, 01:14 PM   #1
particlewave
I'm not saying 100% that the connectors are the issue, but since you didn't mention anything else electrical, that's where I'd start.
The connectors are notorious for causing cluster issues, usually after having removed the cluster for some reason, though it is still the first thing I'd check.
Remove two screws and it pops right out, so it shouldn't take more than 5 minutes. You could also just have a cluster or ignition switch problem.
