Old 08-06-2018, 11:46 AM   #6
MWS
I assume that this appeared after taking the car off the charger? Was there any potential issue (arc, ground,etc) that might have happened when removing charger? Any other strangeness (windows, locks, climate control, spoiler)? Any fuses blown? Does the car start without being on the charger?
As an FYI, I had some electrical gremlins with an old battery that I kept trying to charge; a new battery solved the issues. For now, if your old battery is showing good voltage, you could try disconnecting the battery, waiting a bit and reconnecting. I don't want to dispute particlewave (as he's the expert on most things electrical), but I don't know if the cluster connections are the first thing I would look at if you believe the issue stems from the battery...although disconnecting the cluster and reconnecting might reset.
As always, I look forward to being wrong...but I do wish you success.
