Old 07-30-2018, 08:40 PM   #1
ScottAZ
Originally Posted by Geof3 View Post
I have them, can’t imagine why it would possibly effect cruise control!? Unplug, install, replug. I will tell you the fit is ‘ok’. But not the best, they work. Use the stock seal/gasket as well as the one on the lights it helps. Also, be careful not to over tighten them, the mounting bosses WILL break.
Cool, thanks. The posts I read mentioned something about the cruise control reading the brakes as activated for some reason. I found at least a couple posts that mentioned it. Hopefully it’s a non-issue.
ScottAZ is offline   Reply With Quote
