Old 07-29-2018, 09:29 AM   #14
Bruich10
Originally Posted by Geof3 View Post
No, it’s the other way around. Both ends of the spring are fixed and the spring expands as you press the clutch and essentially pulls the pedal back. With part of your spring on the floor, it is most likely the entire mechanism is broken (just plastic) and the whole thing may need to be replaced.
Still confused but on a high level.
So that means my first assumption was right?
But then i do not see how it at the same time can assist the pedal to go back and meet the cc switch??
I wish i could see a drawing of the pedal assembly from the side so i could see exactly what point moves where around the axis of the pedal - the exploded view earlier in the thread is difficult to interpret.
2003 Boxster S
Seal Grey
Bruich10 is offline   Reply With Quote
