Old 07-27-2018, 04:54 PM   #16
911monty
911monty's Avatar
Originally Posted by 10/10ths View Post
......as far as that rear, center jack point-----The Bentley Manual says that you CAN use that spot as a jack point.
Now, I personally do NOT use it, and I would NOT encourage others to use it.
BUT.......
No Bueno Dude. Have a look at the picture you posted and the one in the Bently manual. Three things stand out. First the spindly aluminum bracket in your pic is not the sturdy black crossmember in the Bently. Second is the cable restraintyou see in the Bently, is at the other end of the triangular aluminum pan piece mounted into that nice sturdy crossmember. Third id the engine is not behind that bracket ala a 911.That jack point indicated in the Bently is as stated near the "center" of the car. However like in the movie Field of dreams "if you supply a jack point they will use it, or something like that.
