Old 07-25-2018, 10:45 PM   #3
Geof3
Originally Posted by MikeMcMo View Post
Right, so if I go get a battery, it may be a day or so before I confirm that the alternator and VR are still good, right? I have read some here and on RennTech where the alternator and battery tests can be erroneous even when tested under load. I like life's little mysteries.. but only to a point.
Ha, no. Mine was a weird series of events. My batt light came on at the track one afternoon, obviously suggesting a charging issue. No obvious issue, light then went off, drove the car home, dead the next day. Bought a new battery put it in, started, showed good voltage no worries. Dead battery next day. The battery failed for some reason, it just died. So, yet another battery, car started, voltage very low... so alt test time. Discovered it was the voltage regulator and swapped it with a Bosch unit. Good to go.
