07-24-2018, 03:10 PM
#2
Originally Posted by PaulE
How does the rest of the headlight fit with the fender. If the headlight fits fine, it looks like your plastic bumper cover isn't all the way seated. Is it the same on both sides? If you don't know when the bumper was last pulled to have the radiators and ducts cleaned out, now would be a good time to do it. Also make sure both your high and low note horns are functioning while you're in there, the bumper cover really needs to be off to change those.
+1 on what Paul said. There is not an additional trim piece. It looks as if you front plastic facia is not seated correctly.
Rgds, Fred
