Old 07-24-2018, 09:13 AM   #25
MN 986
MN 986's Avatar
I had a similar headlight issue recently that was solved with a new headlight switch.
I read an old post on a different forum that a good test for a bad switch is to turn the switch to low beams on. If the lights did not come on, pull the knob out to the foglight position, then pop the knob back in with some force. If the low beams come on, the switch is bad. This confirmed my bad switch, and also helped me turn on my headlights for a couple weeks before I installed the new switch.
MN 986 is offline   Reply With Quote
