even more maintenance
Hi Chaps
Well iv had the gearbox oil changed and it seems quicker into 2nd now. Also had the brake fluid changed.
My mechanic told me at the last service that although the osr outer CV boot want split it was looking a bit perished so got that done too. He ended up doing inner and outer boots as the inner one wasnt much better.
I was there when he had the hub off and both top and bottom ball joints seals are past it too. Slight movement on the top one but none on bottom. I thought I could here a slight chatter back there now and then. So it needs these arms replacing at sometime then re tracking.
Also he says the discs and pad will need doing next year.
Still well within the £1000 per year I budget for things like this so not a problem.
Peter
