Old 09-12-2006, 10:39 AM   #1
rctboxsters
Originally Posted by gjin15
Hello,
I had an Avic N2 installed into my Porsche Boxster by Circuit City. There is a constant buzzing noise from the time I turn on my car and when I turn on my headlights there is static noise. Is anyone experiencing the same problem? Or does anyone out there know what the problem might be?
Also,
does the Porsche Boxster 2002 come standard with AMPS? THANKS!!!
I recently had the Avic N2 installed in my wife's MDX and the same problem happened. It turned out that the installer used the stock amp which creates the engine noise. Bring it back to the shop and ask them to use the deck's amp.
Did you also get that deal with Pioneer? The $ 200.00 rebate for the installation and the free portable GPS with bluetooth?
Make sure to get that because if you purchased the unit before September 5, you are eligible to get that promotion.
I also consider about installing the same unit into my box but decided to wait to see how the portable GPS is. If it does not work out that well, I will go with the Pioneer 9800 since it has built in bluetooth function for my cel.
rctboxsters is offline   Reply With Quote
