Thread: Rear End Noise
Old 07-07-2018, 11:32 AM   #1
911monty
911monty's Avatar
With rear of car on jackstands and in gear, grab a wheel and rotate. If open differential the other wheel will turn in the opposite direction. An LSD will attempt to rotate the other wheel in the same direction.
You can check your option codes under hood. If factory should have IIRC code 220.
