Originally Posted by boomer8800
Does it get higher pitch whine when you step on the gas, if so it's called engine noise the speaker wires are picking it up from a nearby power source. Mostly do to bad grounding on the head unit
Hi,
Actually, if you have a speed dependent whine, it's from the alternator. I agree that grounding is usually the culprit, it's not the engine, but the 3-phase alternator which is ruining your music...
Happy Motoring!... Jim'99
