Old 06-29-2018, 10:26 PM   #18
Geof3
Originally Posted by Eastcoastmod View Post
AOS and oil cooler replaced.
Now the flushing starts.
When I started the process I noticed that the plug for the air intake was unhooked.
When I finished and started the car, it wouldn't idle unless I unhooked it.
Any ideas?
Attachment 21569
Uh, that plug is your MAF sensor... not sure how the car is running without throwing codes with it disconnected. Have you ever had a look with a code reader? Something is not right with your overall system. Could be as simple as needing a new MAF, could be a can of worms... probably has nothing to do with your oil issue though... also, please clean that engine while you are there... makes it happy.
