					Originally Posted by  itsnotanova
				I sell them for $25-50+shipping. Just saying.
 I'd check where it's leaking from before you get rid of it. Could be a bad valve stem. Did you check the air pressure? The bead could have loosen which in return caused a leak. Might just need a good inflate to reseal the bead.
  Good points,  tire may not have had 60psi to start the trip, which it needs to support the weight.
				OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
