Old 06-27-2018, 09:19 AM   #1
BYprodriver
BYprodriver's Avatar
I sell them for $25-50+shipping. Just saying.
I'd check where it's leaking from before you get rid of it. Could be a bad valve stem. Did you check the air pressure? The bead could have loosen which in return caused a leak. Might just need a good inflate to reseal the bead.
Good points, tire may not have had 60psi to start the trip, which it needs to support the weight.
