Old 06-24-2018, 06:25 PM   #1
soxfan1966
I really would not be spraying ANY type of lubricant into the bell housing, it is going to end up on the clutch. The throw-out bearing is sealed, you could submerge it in oil with out any affect. If the throw out bearing is making noise, it is time to take the car apart and fix it properly. There are no short cuts here...……….
I may have misunderstood what was suggested then. He told me to spray some lubricant on it, not in it. I assume that means the end of the slave cylinder that fits inside the transmission then, rather than into the transmission.
The clutch and throwout bearing were replaced two summers ago, about 20k miles.
soxfan1966 is offline   Reply With Quote
