Old 06-14-2018, 02:31 PM   #11
rick3000
There Is No Substitute.
rick3000's Avatar
I always chop the top, I see no reason to unnecessarily add extra stress to the plastic window. I also recommend you avoid putting the top up or down below 70° F, unless the car has been in the sun and the plastic is flexible. If it's a real issue, you can always retrofit a glass window onto older style top frames, but the rear window will be narrower.
