Old 06-03-2018, 11:37 PM   #20
particlewave
Regarding the codes, do you have a Durametric to check fuel ratios? Have you tried disconnecting the MAF to see if it idles better? Smoke tested the intake for leaks (or sprayed with starting fluid)? Are you certain your new purge valve and lines are absolutely sealed?
Since the injectors were just refurbished, there could also be an issue there.
