Old 05-27-2018, 05:43 PM   #1
DWBOX2000
Pads just pop out. I just did. Nothing glued in. Check out instructions for putting roof down manually for name and pictures of part you pop off on each side.
Remove carpet behind seats and over engine cover. Remove 3 nut on each side that hold on roof and remove.
Remove side car carpet pieces vertical (one screw each) in cabin to expose 2 nuts on each side (front of roll bar). Remove nuts.
Back, pop off 2 plastic fasteners on each side and lift padding.
Where rear of roll bar is, there is a soft sponge like foam piece around each bar. Pull out. Two nuts on each side are now exposed. Remove, roll bar will come out.
Have a helper.
If I missed anything someone, please chime in.
DWBOX2000 is offline   Reply With Quote
