Old 05-23-2018, 10:56 PM   #4
Geof3
Yeah, the start up fan is the SAI pump. It kicks off pretty early. If just idling, your fans will kick on and off normally. It is possible your radiators need to be cleaned out, might also want to check your coolant, and if it’s not been done recently, perhaps have your coolant changed. The fan, may or may not run after your car is shut off. Usually, if I’ve been driving pretty hard, my fan won’t be on when I turn the car off, but might come back on after sitting in the garage for a bit. If your temp is stable, I’m not sure it would be much worry.
