Thread: Best tires
Old 05-22-2018, 08:04 PM   #37
Burg Boxster
Square set-up is permissible in Boxster Spec where everything must be stock/spec...
4 fronts will be easy to find... meaning you instead will be looking for 4 rears
Staggered is fine too - especially as you get started... but you won't be able to rotate other than side to side (and not in all cases either depending on tire choice).
Good luck
"Cool Prius!"
- Nobody
